CDR System Reports
One of my gateways is not registering stats in any of the device reports in CDR
I am using UCM 7.1 - Any help in resolving this would be appreciated.
Rod
Green
Re: CDR System Reports
Which type of GW you are referring to (MGCP, SIP or H.323) and which report you are running?
You can check "Documentation Updates" of cucm 7 (Cisco Unified
Communications Manager CDR Analysis and Reporting).
Its a H.323 GW
I can see call stats from CDR and search for gateway (selecting the problem gateway)
However when I select device reports and search by gateway (selecting problem gateway) I don't get any stats.
It reports for CDR but not device reports.
All 6 other gateways produce reports from both device manager and CDR?
Strange
Rod
171
