CDR table name, SQL database name in ccm 7
uniccnp
I would like to know what is the CDR table name and SQL database name in ccm (lunix ver 5,6,7) to pull some of information ???
thanks and regards
Jaime Valencia
Drop the idea of CDR and SQL if you're talking of appliances models.
Only CAR DB exists and we use Informix.
Look at this example:
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
java
if this helps, please rate
java
hi
thanks for your cooperation
please can you send to me Link or PDF that showing me what the DB name and SQL name and type of SQL to pull it
thanks and regards
OK thanks. I think I've ruled it out as our faxing application (Stream) as I can't find a call in the trace files either to the extension for a 20 minute time period that it was happening. Thanks as usual for your help; it's appreciated
Cisco Call Detail Records Field Descriptions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/cdr-defs/cdrfdes.html
CDR Examples
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/cdr-defs/cdrex.html
Table name as listed above "car:tbl_billing_data"
Hope this helps.
