CDR Timestamp 1 Hour Behind--DST Issue
When going through CDR Analysis and Reporting, timestamps are still 1 hour behind when searching by extension.
By doing SQL searches on the CDR database, it looks like the CDR data is timestamped correctly. The server time, and times on all the phones are correct. I assume something in the actual CAR interface. Perhaps java related??
Any insight is appreciated.
Hall of Fame Super Red
Re: CDR Timestamp 1 Hour Behind--DST Issue
Hi William,
Maybe this patch is what you need;
JRE Patch: (ciscocm-2007-JRE-DST-Update.1-0-1.exe)
This patch is only applicable to 3.3(5), 4.0(2a), 4.1(x), and 4.2(x). This patch enables CAR and AST to use the new Daylight Saving Time Zone.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a00807e02b1.shtml
Hope this helps!
Rob
I am having the same problem with CDR records. I have installed the DST updates and everything else is correct. We are running 4.1(3)sr4d.
We have a bug opened for that issue:
CSCsh81417: CDR Analysis and Reporting does not reflect new DST changes
Symptom:
CallManager servers updated with all of the correct DST patches will report
calls in CDR Analysis and Reporting as one hour behind the actual time of the
call between March 11th and April 1st 2007 as well as between October 28th
and November 4th 2007.
The time stamp on the CDR record in the CDR table is correct but reports
generated with CDR Analysis and Reporting will be off by one hour.
Workaround:
Update the JRE component on your Publisher, from the following location:
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-utilpage
Reboot all the servers in the cluster to replicate the changes.
//Jorge
Bronze
Does this also fix RTMT (Real Time Monitoring Tool)?
131
