CDR user on CCM 4.2
Hi All,
I am using CCM version 4.2. I have created a user for accessing CDRs but I have forget the password.
Is there any way to break/restor password?
regds,
aman
1 ACCEPTED SOLUTION
Re: CDR user on CCM 4.2
User Cannot Access ART Since Integrating Active Directory
http://www.cisco.com/warp/public/788/AVVID/art_ad_10153.html
if you have DCD you can look for the same group CiscoAdminRepToolAdminGroupUsers and double-click on it, you will see the name of the user who has admin rights, then you can go into CCMadmin and look for him so you can change the password and log back in
java
if this helps, please rate
www.cisco.com/go/pdi
java
Here is a good link to restoring your password
http://www.cisco.com/warp/public/788/AVVID/restore-art-car-pwd.html#find
Hi Matt,
I have gone through the document.I will do the same & update u.
thanks
aman
After rereading your original post, it sounds as if you know your username. Go to your users in ccm and run a search on that username. Then just change the password on that page.
Hi Javalenc,
Thanks.
The only change which I found was that passowrd for Directory MAnager was cisco instead of ciscocisco.
regds,
aman
114
