CDR Warning: More than 100 records returned. Results truncated.
Customer facing an error, they are preparing a report extension wise after that it says, "Warning: More than 100 records returned. Results truncated." Does anyone know how this is increased.
Customer using CUCM 6.0
1 ACCEPTED SOLUTION
Green
Re: CDR Warning: More than 100 records returned. Results truncat
The CDR Search would return the first 100 matching CDRs. This is mentioned
in ART/CAR online help documents
He needs to generated CSV or PDF report instead of view the report directly.
There also some limits for CSV and PDF as well.
1 REPLY
Green
1322
