CDR
Hi ,
I have a customer using CUCMBE - VER 6 and they want to install a 3rd Party CDR Analyst tool (call Ringmaster). They have advised me that the CDR info can be sent to a remote IP address. However they have not told me how this is to be configured. Does anyone know how this can be accomplished?
Many thanks
Richard
1 ACCEPTED SOLUTION
Re: CDR
Hi Richard,
Please find attached the screenshots to add the billing server.
-> Sushil
Bronze
Re: CDR
not sure if its the same, but in CCM 5.X we can go into CCM Serviceability and there is a CDR management (Under tools) option where i can specify the IP address of a Billing Application server
Re: CDR
I can verify it the same on CM6 and is what I needed thanks for the response.
Re: CDR
Hi Richard,
-> Sushil
Re: CDR
Many thanks for the info
Kind regards
Richard
Re: CDR
I did the exact same steps. But the problem is that no CDRs are sent at all. I tried zeveral times and even tried SFTP servers too. What could be the problem?
Re: CDR
Have you ensured that the CDR Enable Flag is set to true (the default if false)
This can be found under the following
System-> Service Parameters.
Select your Server
Select Cisco CallManager
and it is the first entry on the second box down.
Kind regards
Richard
Re: CDR
Hi Richard,
Yes of course, I have checked that already and it is set to True. I changed the default value from the first day. Any other suggestions?
Re: CDR
hi Sushil,
nice info.
is this the same in ccm4 also.
Re: CDR
Hi Sandeep,
I don't think so. with CCM 4.X as far as I know the third party billing server used to extract information from the CDR database by quering it.
With 5.x onwards ccm pushes the data.
-> Sushil
Re: CDR
Im new with CDR, I have a question about the billing server.., When you said "Billing Server" are you talking about a Cisco Product?.
Can I implement that server?. Can I just send a text file with the cdr records and use my own application to process that file(s) ?.
Thanks.
Re: CDR
hi,
here we were talking about third part billing servers.
-> Sushil
221
