12-03-2008 08:44 AM - edited 03-15-2019 02:53 PM
Can someone tell me the best way to verify I have the correct CDR configuration or if it's activated? CM 4.2.3
12-03-2008 08:55 AM
Hi friend,
CDR is not enabled by default in CM. Please check this URL about Cisco CallManager Configuration.
http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/4_2/4_2_3/cdr423.pdf
Hope this helps.
Best regards,
- Adrián.
12-03-2008 09:23 AM
Hi friend,
Also you can check the section CDR Analysis and Reporting (about configuring CDR Service Parameters and other stuff) from this URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/4_2_3/ccmsrva/sacar1.html
- Adrián.
12-03-2008 09:27 AM
configure it as explained here:
Cause 2
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml#cause2
java
if this helps, please rate
