Community Member
CDR
Hii All,
May I generate the updated CDR Report three times in a day in ccm5.1?
Thanks & regards
Madhab
Re: CDR
linux releases insert the info immediately into the CAR DB so you should be able to run the reports with updated data thru the day
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: CDR
Hii Javalence,
Thanks for reply...plz tell me the what is the procedure to generate the updated report thru the day time by time.
Thanks & Regards
Madhab
Re: CDR
just run the report at different times thru the day, starting with 5.x releases the info is loaded directly into the CAR DB
javalenc
java
Community Member
Re: CDR
Hii,
Thanks for reply. if I run the report , its genereting but not updated. same report which generated at MID night.
so plzz advise me.
Madhab
124
