Community Member
CDRs with wrong time CCM6.0
hi, the system time is right, but the CDRs are comming to the sFTP server, do you know whats going on?
1 REPLY
Re: CDRs with wrong time CCM6.0
if the complaint is that files are using GMT that is not an error, it's working as designed
your billing server is the one that needs to take care of doing the conversion to the proper timezone
java
if this helps, please rate
java
www.cisco.com/go/pdi
104
