Community Member
CER 2.0 working with CCM 7.0
I'm currently installing CER 2.0 and I'm wondering if anyone knows if this will work with CCM version 7.0
1 ACCEPTED SOLUTION
Re: CER 2.0 working with CCM 7.0
You're probably not going to like this
Cisco Emergency Responder
Table 25 provides CER compatibility information for Cisco Unified Communications Manager Release 3.x through Release 7.x.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp45068
CER 7.0(1) is the minimum required for CUCM 7.0
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Community Member
I read the matrix but still wanted to see what would happen. CER registered with CCM and the CTI Ports and CTI Route Points all registered. However I started noticing wierd issues with CER. One issue is when you call back the ELIN it calls onsite security rather than calling the ext it's assigned to in CER. When you change the onsite security number and call the ELIN it calls that new numbers. It seems that JTAPI is having a problem and thats why you have to upgrade to VER 7x. I hope this will help anyone in the future.
123
