CER 3rd Party IBM 3250 M2 Server issue
I am having trouble loading Cisco Emergency Responder 7.0 on a new IBM 3250 M2 server. Before purchasing these servers I emailed my config to TAC and they told me it was supported. Now if I try to install it tells me it can't find the driver for the DVD Drive and to manually select or load one. I opened another TAC case and they are now telling me that this server is not supported. Has anyone run into similar issues? Any thoughts Solutions? My entire server config is below:
4194AC1 IBM System x3250 M2
7283 System Documentation and Software-US English
3650 Dual-Core Intel Xeon E3110 (3.00GHz/1333MHz FSB, 6MB L2)
5162 146GB 15K 3.5" Hot-Swap SAS
9067 Internal SAS RAID - Setup by Customer
9206 No Preload Specify
4156 UltraSlim Enhanced CD-RW / DVD-ROM Combo
2630 Base Hardware
4911 Riser assembly PCI-E
4892 Hot-Swap SAS/SATA Kit 3.5"
3962 2G DDR2 800 SDRAM UDIMM Memory
6311 2.8m, 10A/100-250V, C13 to IEC 320-C14 Rack Power Cable
2798 x3250 M2 Front Bezel
2780 BIOS GBM
4256 Rack Mount Kit
2781 Heatsink Retention Module
2088 3.5" DASD cage
1141 x3250 M2 System Planar
2564 System Packaging - WW
1 REPLY
Bronze
Re: CER 3rd Party IBM 3250 M2 Server issue
The IBM 3250 M2 server is not a supported platform. It is an IBM server, not an MCS.
This is the list of IBM server configs that are equivalent to MCS models, and can be used to install Cisco products:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview0900aecd80091615.html
414
