CER 7.1(1) utils dbreplication status
For the sake of Google and helping others, here is what a good Cisco Emergency Responder 7.1.1 database replication
status looks like.
CER Database Replication
from CER publisher here is what a good utils dbreplication status should look like
admin:utils dbreplication status
-------------------- utils dbreplication status --------------------
Output is in file /var/log/active/er/trace/dbl/sdi/ReplicationStatus.2010_02_13_09_19_28.out
Please use "file view activelog er/trace/dbl/sdi/ReplicationStatus.2010_02_13_09_19_28.out " command to see the output
admin:
admin:file view activelog er/trace/dbl/sdi/ReplicationStatus.2010_02_13_09_19_28.out
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_cer001_cer7_1_1_10000_5    2 Active   Local           0
g_cer002_cer7_1_1_10000_5    3 Active   Connected       0 Feb 11 08:55:12
end of the file reached
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 4 of 4) :
admin:
Community Member
You are absolutely correct on this one.
Spent all night on this one (with TAC).  You are correct, the only db replication indicator in CER (8.0) it seems is the "status" option.  No Cisco Reported, no "utils replication runtime".  We saw your post but had no other corroberation.  Funny, we all see status should =2 but not for this command (even in CCM, it should show '3  Active' if just pub and sub).
Thanks for the post.
Community Member
I too have scratched my head
I too have scratched my head on this one when seeing the 3 there.  Thanks for the post.
Warner
Community Member
same on v9
same on v9
g_usbpcer01_cer9_0_2_10000_1 2 Active Local 0
g_usshkcer01_cer9_0_2_10000_1 3 Active Connected 0 Jul 31 18:34:26
Community Member
same on v11
same on v11
admin:file view activelog er/trace/dbl/sdi/ReplicationStatus.2017_01_16_19_54_29.out
Mon Jan 16 19:54:29 2017 main() DEBUG: -->
Mon Jan 16 19:54:30 2017 main() DEBUG: Replication cluster summary:
g_2_cer11_0_1_10000_3 2 Active Local 0
g_3_cer11_0_1_10000_3 3 Active Connected 0 Jan 16 18:16:50
Mon Jan 16 19:54:31 2017 main() DEBUG: <--
877
