CER backup and restore
we have a CER in the lab, I start configuring the CER. I need to backup configuration and restore to a new CER with the same version. when I backup from CER, it creates 8 tar files. which tar file is related to the configuration?
thanks for any suggestion
Alex
1 ACCEPTED SOLUTION
Red
Re: CER backup and restore
You'll need all of them.  They are for different components (such as database, platform, etc.)
Actually, the backup will generate an XML file.  The same XML file will be used for restore.
Michael
http://htluo.blogspot.com
1 REPLY
Red
Michael
164
