CER Bulk Import
mightyking
Level 6
Level 6
Hi Guys,
I have 15 buildings, each has in avarage 6 floors; each floor is devided in half; east and west wing. I have to creat about 120 different zones (ELIN). The most important part for me is to be able to put description in each port. Is there a way that I can bulk import the required info?
MK
Tommer Catlin
Every version of CER seems a little different on how it import/exports.  id start by configuring one building or floor and then exporting it to CSV.  Open in EXCEl and edit the port names you like.  Import it back in.  If this looks correct, this is your template.  I have gone through and done this with Switchport Descriptions.  Its a pain, but this is the only way you can add descriptions to switchports.
