You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
CER ELIN Test
We are running CER ver 7.0.1.  Does anyone know if it is possible to test a 911 call to see what ELIN is being sent to the PSAP without actually sending the call?
  • IP Telephony
Everyone's tags (3)
1 REPLY
Silver
CER ELIN Test
You could block it at the gateway and see what you're receiving.  You could also create a separate test pattern with the same behavior as 911 up until it hits the gateways to use for testing.
206
