CER integration to two CUCM clusters - CUCM Version different ok?
Per the following links
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/7_0/english/administration/guide/e911plan.html#wp1045228
and
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cer/7_1_1/english/administration/guide/e911ccm.html#wp1067379
a single CER cluster can support more than a single CUCM cluster. The question I have is would the CUCM clusters have to be the same version? Or could they be different as long as they were compatable versions with CER?
Casey
1 REPLY
Re: CER integration to two CUCM clusters - CUCM Version differen
I have ran two different versions of CM with CER, but it was a while ago.  I am not aware of any reason why you would be unable to do this as long as both CUCM versions are compatible with CER.  Which can be determined here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp50332
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
758
