CER Phone Tracking After Switch Replacement
Some switches were replaced last night and we are seeing odd results from the phone tracking. Could someone please tell me if the switch version is compatible with CER?
From the release notes I see 12.2.(55)SE is supported. I would assume SE7 would be as well.
WS-C2960S-48FPS-L  12.2(55)SE7           C2960S-UNIVERSALK9-M     CER 8.6.10000-11
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/8_6/english/release/notes/cer_86.html#wp166808
thx
J
Hall of Fame Super Silver
Every release notes of CER lists supported switches.
HTH,
Chris
Right that is why I linked in post.
But the matrix shows 12.2(55)SE
The current version on switch is SE7. Does it mean only SE is supported and not SE7?
SE7 should be supported, in fact the version is not that significant as CDP and SNMP changes are not usually changed in the switches.
HTH,
Chris
Thanks for the help Chris. I would think it would be as well. But just odd there would be problems after they were replaced with the new image.
197
