CER, RTT requirement between PUB and SUB
cjrchoi11
I have two data centers and will be installed CUCM_PUB and CUCM_SUB in each location. and I want to install CER servers in each location as below combination but cannot find out CER requirement from CCO.
-data center1, CUCM_PUB, CER_PUB
-data center2, CUCM_SUB, CER_SUB
Q)
-can I install CER servers with the above combination?
-what is CER RTT (or something else) requirement between CER Publisher and Subscriber?
-CUCM RTT requirement is 80ms (after version 6.1). Is CER requirement belonging to CUCM?
***the CER subscriber requirement as per CER admin guide,
'Consider installing the standby server in a physically separate location from the primary server, and on a separate subnet not separated by a WAN link'
https://www.cisco.com/en/US/docs/voice_ip_comm/cer/7_0/english/administration/guide/e911plan.html#wp1045315
Advise plesae,
John
gogasca
Level 10
Level 10
Hi John,
There can be up to 40 msec RTT between a CUCM server and a CER server in a CoW
deployment.
This implies that there will be no more than 40 msec RTT between
CER publisher and CER subscriber as well.
If I remember correctly, the minimum bandwidth between CER publisher and
subscriber was the equivalent of a T1.
I'm not aware of any maximum delay or minimum bandwidth between CER servers in
different server groups.
