CER Upgrade
We are currently running CER ver 7.0.1.  A field notice was released FN#63307 instructing users to install and update (7.0.3).  There are now several updates:
CER 7.1.1.10000
CER 7.1.1.20000
CER 7.1.1.30000
Can we just upgrade to CER 7.1.1 without installing the 7.0.3 update?  Should we just install the lated CER 7.1.1.3000?
1 ACCEPTED SOLUTION
Re: CER Upgrade
Yes, you can upgrade to the latest 7.1 release from 7.0(1):
http://www.cisco.com/en/US/docs/voice_ip_comm/cer/7_1_1/english/release/notes/cer_711.html#wp39778
You should also check your CUCM release to be sure that you are covered there as well:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp50332
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
1 REPLY
Re: CER Upgrade
HTH.
Bill
448
