Community Member
Certificate (MIC) on 9971/9951
Does the ip phones 9971 and 9951 have MIC (Manufacturer Installed Certificates).
If so, how do I get the public ca certificate of this MIC?
On the 7925G it can be downloaded via the phone's web interface, but there is no such menu option on 9971.
Community Member
Re: Certificate (MIC) on 9971/9951
I'm still searching for an answer to this question
Yes, they do.
Sorry, I can't help you here.  I just saw that you were asking for a follow up and I figured I would give the same answer I would have initially.  Personally, I am not sure why you would need this information and it is recommended to replace the MIC with a new cert.  But I won't pretend to be the mac on the MIC.  Good luck.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
1068
