Certificates change on secure-cluster
Hi everybody,
One of my customer has a secure cluster of 2 CUCM and I have to deploy a new CUCM IM & Presence cluster on that installation. When I did the initial installation, I didn't configure any domain name or DNS server, and I know that will be a problem with Jabber : users will have to validate a security message about certificates.
So, I want to set dns server and domain names on the CUCM. And this will generate new certificates. I did that before on NON-SECURE clusters, the only thing to do before is to check the "Prepare Cluster for Rollback to pre-8.0" enterprise parameters to empty the ITL File. But what will happen in the case of a SECURE cluster ?
Thank you in advance for you answers.
François Lieuze
1 ACCEPTED SOLUTION
Hi Francois,As per the
Hi Francois,
As per the following doc 'If you use CTL files or tokens, re-run the CTL client after you change the IP address or hostname of the server, or after you change the DNS domain name.'
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/8_6_1/ipchange/ipchg861.html
Manish
Hi again, Sorry for the "up",
Hi again,
Sorry for the "up", but Can anyone help me ?
Thanks, regards.
François
Hi Francois,
Manish
85
