Certified Cisco CDR vendors
Does anyone know if Paetec Pinnacle is a Cisco third party CDR vendor. Or does anyone have Paetec Pinnacle working with CCM CDR?
Any help is appreciated.
1 REPLY
Silver
Re: Certified Cisco CDR vendors
The CDR format most often used by softswitch vendors to generate CDRs is the Bellcore AMA Format, described in Billing Automatic Message Accounting Format (BAF) Generic Requirements (BAF-GR-1100-CORE). Unfortunately for the next-generation of Voice over IP (VoIP) applications, such as SBC, the BAF format is too telephony specific, and does not contain sufficient provision for IP-centric logging information. (For example, it does not allow for logging of Session Description Protocol (SDP) or RTCP statistics). In addition, the format is not extensible, so it is not possible to define extensions to contain these fields.
169
