01-15-2010 10:41 AM - edited 03-18-2019 11:00 AM
CFA not working to external numbers, but do work to internal DN's.
99.5% sure it's not a CSS issue. When making calls to DID w/ CFA set, I get an error message from carrier. We have a SIP trunk to CUBE router, then SIP trunk to CUCMBE (7.1.3). Ran debug ccsip message on CUBE router, and call fails going to CUCMBE. Get a error 404. I'm attaching debug to discussion.
01-20-2010 09:28 AM
Looks like you are getting a Q.850 cause code of 1, which is unassigned/unallocated number. Can you call this number directly? If you can, can you pull the debug from a sucessful call for comparison?
01-20-2010 10:52 AM
Hello Ryan,
Has stated this indicates
the clear code is unallocated/unassigned number, this suggests the status of the
dial peer is down.
Or it is possible that there is no route for 6108542201.
Could you attach
show dial-peer voice summary
And we can go from there.
J
01-20-2010 11:45 AM
DR-voice#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
100 voip up up 61040729.. 0 syst ipv4:172.17.2.3
101 voip up up 61085422.. 0 syst ipv4:172.17.2.3
110 voip up up 6106409485 0 syst ipv4:172.17.2.3
111 voip up up 6106409836 0 syst ipv4:172.17.2.3
120 voip up up 484913020[56] 0 syst ipv4:172.17.2.3
200 voip up up 81[2-9][0-8].[2-- 0 syst sip-server
9]......
201 pots up up 81[2-9][0-8].[2-- 1 down trunkgroup POTS
9]......
300 voip up up 8011T 0 syst sip-server
301 pots up up 8011T 1 down trunkgroup POTS
900 voip up up 8[2-9]11 0 syst sip-server
901 pots up up 8[2-9]11 1 down trunkgroup POTS
01-20-2010 11:55 AM
Actually, looking at it again, Q.850:1 is what the gateway is sending to the CUCM server. The gateway is getting a Q.850:27 from the remote end of the SIP trunk, which is "Destination Out of Order". It looks like the Dial-peer is getting matched correctly, but the remote end is refusing the connection. I don't think the CFA component has anything to do with it. I think the problem is on the remote gateway.
01-20-2010 12:06 PM
So I guess I'm not getting the call flow here.
You said this was for CFWD to external numbers.
I assume the 172.17.2.3 is CUCMBE, and we see from the debug 610854220 coming back in from sip:8563807151@10.200.10.5.
This debug looks like an inbound call to CUCMBE not a outbound call to PSTN.
J
01-20-2010 01:24 PM
Hi Ryan,
I hope you are doing well, so from what i have understood your topology looks like the following.
Ip Phone-->CallManager--Sip Trunk-->Cube--Sip Trunk-->CUCMBE-->Ip Phone
Please let me know if i have understood this correctly, moving ahead
we have received a "404 not found" error, which occurs because of the following:-
1. This response indicates that the server has definite information that the user does not exist in the specified domain.
2. The SIP gateway generates this response if it is unable to locate the callee.
3. Upon receiving this response, the gateway initiates a graceful call disconnect and clears the call.
Can you please attach the "Debug Ccsip All" for the complete call, as i am not able to see the disconnect message.
Could you do a "Show Dialplan number(the called number) & check which dial-peer is being hit.
Also could you please attach a show runn of your cube router.
Please let me know if this helps.
Amit.
