CFA to PSTN, how to release the call from gateway?
-CUCM6.1
-SRST router with FXO lines. h323
Under voice-port, configure the target number '91800xxxyyyy' and let the incoming call back to PSTN
Q)is there any feature to release the call from SRST router?
Thanks in advance,
Hall of Fame Super Gold
Re: CFA to PSTN, how to release the call from gateway?
Short of shut/no shut the voice-port, there's no way. There is also a"clear voice call" command, but it's broken in most IOS versions.
I may not explained clearly.
the incoming call forwarded to 1800 (PSTN) in SRST router but the call still stay in SRST router until hang-up and also occupy two FXO lines.
Is there any way to release from SRST router after the incoming call forwared to 1800(PSTN)?
John
If you configure CFA at router level, it is normal that each call will take two lines.
If you want CFA not to take any line, configure it at telco level.
131
