CFB or CFNA Softkeys
izackvail
Is it possible to create CFB or CFNA softkeys in Call Manager 6.0.1?
gogasca
Level 10
Level 10
nop, CCM user is the option
gogasca
Level 10
Level 10
I assume that is a nope. :) Thanks for the reply.
Rob Huffman
Hi Izack,
I believe the latest version of this 3rd party product includes the CFNA and CFB settings change capability;
IPPhone callForwarder
This new version brings to the user the ability of defining and setting the call forwards from the IP Phone. When selecting the IP Phone callForwarder service, a menu with all available lines will appear. After selecting the line the user wishes to set the forward on, a new menu containing the forward definitions will show on screen. Only those forwarding parameters definied by the Administrator will be displayed. These parameters will show the actual forward destination. The user can then set any of these callForwards.
From this good link;
http://www.myvoipsource.org/index.php?option=com_content&task=view&id=47&Itemid=85
Hope this helps!
Rob
Thank you Rob!
