CFB SCCP not operational
Hi There,
I'm trying to configure a Gateway dsp for conference on CCM 6.1 (SCCP) but SCCP state is not operational.
following conf and trace:
I did this config:
RO-FR-VIL-CIM-2821-1#sh running-config |
voice-card 0
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/1
sccp ccm 10.214.6.10 identifier 1 version 6.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 1 register conf-vill
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
maximum sessions 8
associate application SCCP
and show sccp
RO-FR-VIL-CIM-2821-1#show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/1
IPv4 Address: 10.241.13.1
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.214.6.10, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 1
Reported Max Streams: 64, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
debug sccp:
000259: Dec 2 20:29:25.578 WET: sccp_oper_state_bring_up: Not able to create MP Auto-Config process
000260: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 5
000261: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 6
000262: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 5
000263: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 6
000264: Dec 2 20:29:25.586 WET: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
000265: Dec 2 20:29:25.586 WET: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
000266: Dec 2 20:29:25.586 WET: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
thanks for your help.
Re: CFB SCCP not operational
Verify that you are using the exact same name in CCM: conf-vill it is case sensitive. Then try a no sccp and then sccp.
Also how are you adding the HCB in CCM? as enhanced IOS or plain IOS?
hi,
the name is ok. HCB type is "enhanced IOS".
strange..
Best reagrds
Hall of Fame Super Silver
Hello Jerome,
you should verify that the device can access the call manager on TCP port 2000: there is any router or firewall on the path ?
this is from one conference bridge in our network
V-RMSXR00-CB01#show sccp
Gateway IP Address: 10.80.128.54, Port Number: 2000
IP Precedence: 5
Call Manager: 10.28.144.12, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 1
Call Manager: 10.24.144.14, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 2
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.28.144.12, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
it is registered :
Conference Bridge InformationConference Bridge : V-RMSXR00-CB01 (V-RMSXR00-CB01)
Registration Registered with Cisco Unified Communications Manager 10.28.144.12
Hope to help
Giuseppe
hello Giuseppe,
the router can join CCM on port tcp 2000 and there is no firewall between Router and CCM.
I think the problem comes from the router (but I'm not sure) see "debug sccp" but I can not interpret :-(
Best regards.
Silver
Is it not the version number being 6.0 maybe change it to 4.0 - I think I remember a similar post????
actually my CUCM are 6.1.2 but on the device I have
sccp ccm 10.28.144.12 identifier 1 version 5.0.1
Hope to help
Giuseppe
actualy CUCM are 6.1.1
i test the following parameters:
- sccp ccm 10.214.6.10 identifier 1 version 6.0
- sccp ccm 10.214.6.10 identifier 1 version 5.0.1
- #sccp ccm 10.214.6.10 identifier 1 version 4.1
and the result is same...
see debug sccp error:
000404: Dec 4 15:23:50.856 WET: sccp_oper_state_bring_up: Not able to create MP Auto-Config proces
000405: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 5
000406: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 6
000407: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 5
000408: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 6
000409: Dec 4 15:23:50.864 WET: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero
000410: Dec 4 15:23:50.864 WET: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
000411: Dec 4 15:23:50.864 WET: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
hi,
strange..
Best reagrds
Try changing it to only IOS, do not use enhanced, I ran into a bug a while ago with CCM 6 and HCB, it did not registered while using enhanced IOS Conference Bridge, I had to changed it.
//J
I'm verify with 2 configuration (enhanced IOS and IOS) same result..:-(
I check if this problem is Hardware.
best regards
Hi it's ok with CCM 6.0 and type IOS.
thank's for your help
3414
