Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CFNA fails to forward external calls
Hello Everyone,
     I have Call Manager running 7.0.1.11000-2. I'm having difficulty with one user who has set their phone to forward to their mobile on no answer from external calls. The call reaches the phone, then when forwarded to the users mobile phone the calling party is informed that number is unreachable or disconnected.
I have tested the forward function for the users phone by forwarding all calls to the users phone to the same mobile phone and this worked as expected.
A debug of the voice gateway shows the following.
Feb 10 15:27:04.161: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1EEB
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '<removed>'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '<removed>'
Plan:ISDN, Type:Subscriber(local)
Sending Complete
Feb 10 15:27:04.169: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9EEB
Channel ID i = 0xA98381
Exclusive, Channel 1
Feb 10 15:27:04.233: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x9EEB
Feb 10 15:27:34.261: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9EEB
Cause i = 0x8081 - Unallocated/unassigned number
Feb 10 15:27:34.329: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x1EEB
Feb 10 15:27:34.329: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9EEB
Not sure where to progress from here, eager to hear everyones suggestions.
Thank you,
Peter
1 REPLY
Re: CFNA fails to forward external calls
  OK guys,
Good news, this has been resolved. CFA was using the wrong calling search space.
294
