CFW All not working for external Calls
I have a CUCM 8.6 and a SIP TRUNK for external calls, when i forward extension A to a external number and i try to call extension A i receive a busy tone.
The outgoing and incoming calls are working and the call forward all for internal number are working.
Follow my config:
telephony-service
call-forward pattern .T
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Eliminate Diversion header.
I think the same can be done with a voice translation-profile, eliminating redirect-target.
Re: CFW All not working for external Calls
Seem like you're running CME, not CM.
Possibly, the ITSP doesn't allow you to send a calling number that is not assigned to you.
You can take debug "ccsip message" with "term mon" to confirm.
I think yes, i ll try to put this command:
Router(config)#voice service voip
Router(conf-voi-serv)#no supplementary-service sip moved-temporarily
I will let you now
Thanks!
How can i confirm that the ITSP doesnt accept the caller ID?
Doing what I've already indicated above.
Sorry Paolo is a CUCME i forgot the "E".
Thanks!
Hello Paolo i put the command
and didnt work
follow the debugs?
Jan 10 11:04:46.772: //17203/BDDA3C80B72A/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x319B9CA8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 1148900510
Called Number            : 65263373
Source IP Address (Sig  ): My IP
Destn SIP Req Addr:Port  : SIP PROXY:5060
Destn SIP Resp Addr:Port :SIP PROXY
Destination Name         :SIP PROXY
GWFIVETEN01#
Jan 10 11:04:46.772: //17203/BDDA3C80B72A/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): My IP
Source IP Port    (Media): 16746
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
Do you have any idea? Im sendind the main number as the calling, and the called number is on the right format.
I have indicated above the debugs you should take.
Follow the output of the ccsip messages:
Sent:
INVITE sip:65263373@10.210.65.16:5060 SIP/2.0
Via: SIP/2.0/UDP 10.213.26.98:5060;branch=z9hG4bK48B8
Remote-Party-ID: <1148900510>;party=calling;screen=no;privacy=off
To: <65263373>
Date: Tue, 10 Jan 2012 15:47:34 GMT
Call-ID: 3F7B7DAD-3AD911E1-804FDD04-43CEEA6E@10.213.26.98
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1065057709-0987304417-2152455428-1137633902
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1326210454
Contact: <1148900510>
Diversion: <511>;privacy=off;reason=unconditional;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 355
v=0
o=CiscoSystemsSIP-GW-UserAgent 7789 6280 IN IP4 10.213.26.98
s=SIP Call
c=IN IP4 10.213.26.98
t=0 0
m=audio 28792 RTP/AVP 18 8 100 101 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
Jan 10 15:47:34.547: //19/3F7B7DAD804B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <65263373>;tag=6521420521392012110134833
CSeq: 101 INVITE
Server: CS2000_NGSS/9.0
Contact: <10.210.65.16:5060>
k: 100rel
Content-Length: 0
Jan 10 15:47:34.595: //19/3F7B7DAD804B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
CSeq: 101 INVITE
k: 100rel
Allow: ACK,BYE,CANCEL,INVITE,OPTIONS,INFO,SUBSCRIBE,REFER,NOTIFY,PRACK
Content-Length: 0
Jan 10 15:47:34.595: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
GWFIVETEN01#ACK sip:65263373@10.210.65.16:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thanks Paolo!
Now you can compare with a normal working call, and fidn the difference, likely calling number or other identify detail.
1267
