CFW between two Sites is not properly working
Hi there,
I got a strange phenomenon at the moment, which I don`t understand.
Some weeks ago I did some changes, which may had some influence on this problem.
We´ve got to Sites with Communication Manager Express. When I make a Call forward for a DN from Site 1 to a Broadcast Hunt Group of Site 2 and try to reach that DN of Site 1 with a Phone on Site 1, no call get`s established.
Range of Numbers in Site 1: 300 - 399
Range of Numbers in Site 2: 100 - 199
For example:
Call from DN 100 (Site2) to DN 300 (Site1), DN 300 is busy and the call is forwarded to a Broadcast Huntgroup on Site 2 (for example: 199). The Phones on Site2 don`t ring and on the Calling phone (DN 100) you here nothing (no busy tone or anything else).
If I call from PSTN and not via WAN, the call gets established although DN 300 is forwarded to 199.
If I configure a sequentiell Huntgroup, the phones ring and the call is established when I call via WAN?! (This is the workaroundfor the moment)
Here are the Voip dial-peers:
Site1:
dial-peer voice 2 voip
preference 1
destination-pattern 1..
progress_ind setup enable 3
modem passthrough nse codec g711alaw
session target ipv4:172.16.100.3
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric
fax rate disable
fax protocol pass-through g711alaw
no vad
Site2:
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 299
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
So the problem obviously just exisits, when I make a call to a busy DN of the other Site via WAN, which is forwarded to a Broadcast Huntgroup.
Any Ideas where the problem is.
It worked some time ago....
Thanks in advance,
VoiceDealer
Hall of Fame Super Silver
Post debug voice dialpeer, also make sure you have forward-pattern defined under telephony-settings.
Chris
Re: CFW between two Sites is not properly working
Hi Chris,
thanks for your help!
A Call-forward pattern is configured on both sites under the telephony services:  "call-forward pattern .T"
Here is a "debug voice dialpeer" of "Site1":
Jan 27 08:34:52.164: //-1/5B8B0A9CBA56/DPM/dpAssociateIncomingPeerCore:
   Calling Number=131, Called Number=320, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2
Jan 27 08:34:52.164: //-1/5B8B0A9CBA56/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jan 27 08:34:52.168: //-1/5B8B0A9CBA56/DPM/dpAssociateIncomingPeerCore:
Jan 27 08:34:52.168: //-1/5B8B0A9CBA56/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:52.168: //-1/5B8B0A9CBA56/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=320, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=320
   Result=Success(0) after DP_MATCH_DEST
   dialstring=320, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 27 08:34:52.168: //-1/5B8B0A9CBA56/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20007
Jan 27 08:34:52.172: //-1/5B8B0A9CBA56/DPM/dpMatchPeersCore:
Jan 27 08:34:52.172: //-1/5B8B0A9CBA56/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:52.172: //-1/5B8B0A9CBA56/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 27 08:34:52.172: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=320, Called Number=320, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 27 08:34:52.172: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:52.172: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 27 08:34:52.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=320, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Result=SUCCESS(0)
   dialstring=320, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
Jan 27 08:34:52.184: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=131, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=131
Jan 27 08:34:52.184: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=131, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 27 08:34:52.184: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Jan 27 08:34:52.192: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 27 08:34:52.192: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:52.192: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Result=SUCCESS(0)
Jan 27 08:34:56.188: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=130, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=130
Jan 27 08:34:56.188: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=130, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 27 08:34:56.188: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Jan 27 08:34:56.192: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:56.192: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Jan 27 09:34:56.192: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 5B8B0A9C866411E3BA56BE3F5C24CD49, SetupTime 09:34:52.182 CET Mon Jan 27 2014, PeerAddress 320, PeerSubAddress , DisconnectCause 13  , DisconnectText no user answer (19), ConnectTime 09:34:56.192 CET Mon Jan 27 2014, DisconnectTime 09:34:56.192 CET Mon Jan 27 2014, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Jan 27 09:34:56.192: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFNA,ft:01/27/2014 09:34:56.192,frs:0,fid:1485,fcid:5B8B0A9C866411E3BA56BE3F5C24CD49,legID:2E9,frson:3,fdcnt:1,fwder:320,fwdee:131,fwdto:130,frm:320,bguid:5B8B0A9C866411E3BA56BE3F5C24CD49
Jan 27 09:34:56.192: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/27/2014 09:34:52.176,cgn:131,cdn:320,frs:0,fid:1484,fcid:5B8B0A9C866411E3BA56BE3F5C24CD49,legID:2EA,bguid:5B8B0A9C866411E3BA56BE3F5C24CD49
Jan 27 08:34:56.200: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=320$, Called Number=, Voice-Interface=0x0,
Jan 27 08:34:56.200: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:56.200: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   dialstring=130, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Jan 27 08:34:56.200: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Jan 27 08:34:56.204: //-1/5B8B0A9CBA56/DPM/dpMatchPeersCore:
Jan 27 08:34:56.204: //-1/5B8B0A9CBA56/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:56.204: //-1/5B8B0A9CBA56/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
Jan 27 08:34:56.204: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 27 08:34:56.204: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 27 08:34:56.204: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
And then I quit the call (hang up):
Jan 27 09:35:57.854: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 5B8B0A9C866411E3BA56BE3F5C24CD49, SetupTime 09:34:52.174 CET Mon Jan 27 2014, PeerAddress 131, PeerSubAddress , DisconnectCause 7F  , DisconnectText interworking (127), ConnectTime 09:35:57.854 CET Mon Jan 27 2014, DisconnectTime 09:35:57.854 CET Mon Jan 27 2014, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Jan 27 09:35:57.854: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFNA,ft:01/27/2014 09:34:56.200,frs:0,fid:1488,fcid:5B8B0A9C866411E3BA56BE3F5C24CD49,legID:0,frson:3,fdcnt:1,fwder:320,fwdee:131,fwdto:130,frm:320,bguid:5B8B0A9C866411E3BA56BE3F5C24CD49
Jan 27 09:35:57.854: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/27/2014 09:34:52.168,cgn:131,cdn:320,frs:0,fid:1483,fcid:5B8B0A9C866411E3BA56BE3F5C24CD49,legID:2E9,bguid:5B8B0A9C866411E3BA56BE3F5C24CD49
Jan 27 08:35:57.858: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1.., Called Number=, Voice-Interface=0x0,
Jan 27 08:35:57.858: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
What is configured:
I try to call DN 320 on Site1 from DN 131 on Site 2. DN 320 has a CFNA (after 4 Seconds) to a Broadcast HG on Site 2 (130). The call doesn`t get established.
Thanks n Regards,
VoiceDealer
125
