Community Member
Cfwdall Off-net to Off-net
I am at a loss. I still cannot forward a call off-net from an off-net call. I have checked under service manager, not blocking. Tested multiple CSS settings, everything works as advertised. I can fwd off-net from an internal number fine. What am I missing.
Setup
CUCM 7.1.5
H.323 Gateways.
Thanks in advance
Rich
Everyone's tags (2)
Re: Cfwdall Off-net to Off-net
Please take a look at the following thread:
https://supportforums.cisco.com/message/3187809
Tapan
Community Member
Thanks for the pointing out.
But, this hasn't resolved my issue.
Hall of Fame Super Gold
Take, "debug isdn q931" with "term mon" and post it here.
Do not take any other debug, do not use attachments.
Community Member
Below is from my incoming gateway. I have 2, 1 in and 1 out. The outbound gateway doesn't see the call.
632199: *Sep 29 08:36:04.390 ET: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0237
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838F
Exclusive, Channel 15
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2181, 'XXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '3017'
Plan:Unknown, Type:Unknown
632200: *Sep 29 08:36:04.406 ET: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8237
632201: *Sep 29 08:36:04.646 ET: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8237
Cause i = 0x809B - Destination out of order
632202: *Sep 29 08:36:04.686 ET: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0237
632203: *Sep 29 08:36:04.690 ET: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8237
Community Member
So after posting above I kind of stumbled on what I thought was going on. Seeing as I have 2 gateways I started checking to see if they were talking to each other. Well, my limited knowledge in that didn't come up with anything. So, for a temporary fix, I have created a new CSS, that uses a route pattern, which looks at a reversed ooutbound RG. So when a call comes in my inbound gateway, it gets turned right around and sent out the same gateway. I am going to use this as a temporary fix, but if someone can give me some insight on how to get this working properly I would be greatly appreciative.
Rich
Very good, please remember to rate useful posts clicking on the stars below.
550
