You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
CFwdALL to mobile number not working
Hello everyone.    I have an issue that I've been trying to resolve since we upgraded from CallManager 7.1.5 to 9.1.2.12900-11.  I am able to forward my desk phone to my mobile phone, but when I call my desk phone, I get  an immediate fast busy.  I've been scouring the Internet for similar issues, but I cannot find a resolution to my issue.
Here's a little bit of info:
1 Pub
2 Subs
2 Voice Gateways
3 Local PRI's.
What I've done:
1)  I logged into each server and verified that database replication was happy using the utils dbreplication runtimestat command.
2)  I checked the codec from desk phone to desk phone, from desk phone to mobile phone, and mobile phone to desk phone, all at G.711ulaw.
3)  Verified that the Clusterwide Parameters (Feature - Forward) options were the same as version 7.1.5, which they are.  The CFA CSS Activation     policy is set to "With Activating Device/Line CSS (although the recommended setting is With Configured CSS).
4)  Checked my device line configs. The Calling Search Space Activation Policy is set to Use System Default, and the Forward All is set to the local CFW search space, same as the old system.  I also checked the CSS to ensure that a partition wasn't left out or removed after the upgrade, and everything is the same.
5) Debug the local PRI. logged on to the Voice Gateway handling our two local PRI's and turned on ISDN Q931 debugging.  The output is below:
This is a call from my desk phone to my cell phone
Aug  7 15:12:29.256: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x153B
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Display i = 'John Doe'
        Calling Party Number i = 0x2181, '2605551212'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2605551313'
Aug  7 15:12:29.296: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
53B
Aug  7 15:12:31.236: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x95
3B
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Aug  7 15:12:31.616: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
153B
        Cause i = 0x8090 - Normal call clearing
Aug  7 15:12:31.624: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x953
B
Aug  7 15:12:31.652: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
This is a call from an internal extension calling my desk phone, which is forwarded to my mobile
Aug  7 18:22:53.163: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1578
                Standard = CCITT
        Display i = 'Joel Fox'
        Redirecting Number i = 0x00008F, '1234'
                Plan:Unknown, Type:Unknown
Aug  7 18:22:53.203: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
578
Aug  7 18:22:53.303: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
9578
        Cause i = 0x82AF - Resource unavailable, unspecified
Aug  7 18:22:53.331: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x157
8
Aug  7 18:22:53.339: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x9578u all
I just have no idea why it is being dropped... Looking up the cause, others had issues with codec mismatch, which is why I checked that in the first place...
Any suggestions are greatly appreciated!
  • IP Telephony
1 ACCEPTED SOLUTION
the difference is, in your
the difference is, in your second call, the forwarded call. you are sending '1234" as the redirected number to your provider. (obvisouly not happening in your first call).
you might want to go to the gateway in CUCM that sends the call to PSTN and uncheck:
"Redirecting Number  IE delivery - outbound"
============================= Please remember to rate useful posts, by clicking on the stars below. =============================
go CUCM administrationgo to
go to phone line1 Call Forward and Call Pickup Settings
Thank you - That worked!
Thank you - That worked!  Honestly I overlooked that completey thinking it was something much more complex since we just went through an upgrade.  Of course I was rushing through things and should have caught that...
I rated this but for some reason it's not letting me mark it as a correct answer...
Thanks again
Joel
"Cause i = 0x82AF - Resource
"Cause i = 0x82AF - Resource unavailable, unspecified".
Your SP was not taking your call request and rejected it. The Types and Plans of the calling/called parties are the same in the two calls, so the only information might break it is the redirecting number. It seems your SP doesn't like it. Uncheck "Redirecting Number  IE delivery - outbound" and capture another ISDN Q.931 output.
Hope that helps.
Thank you Gary - minkdennis
Thank you Gary - minkdennis suggested the same resolution.  As I told him, I overlooked that completely expecting a complex issue.  It's odd that it worked prior to the upgrade, but it's working now so I'll let it ride :)
Thanks again
Joel
236
