Change 8941 8945 wallpaper background image ?
Hi all,
How can I change the background image on my 8941 ?
Is it possible ?
Philippe CUVILLIER
Cisco Video 8900 http://www.youtube.com/watch?v=zNmiOFXJcws
B2GAAS  http://www.youtube.com/watch?v=4OD0Zp9HJ9ghttp://www.youtube.com/watch?v=4OD0Zp9HJ9g
Ciso Ipad Video http://www.youtube.com/watch?v=VNRL9sSuQCw
Softphone and 8941  http://www.youtube.com/watch?v=ELWgl4p8az0
Gordon Ross
Level 9
Level 9
Settings->Preferences->Wallpaper, perhaps ?
GTG
Please rate all helpful posts.
Actually it's not currently supported to change the background on those models, if you look at the admin guide the spot where you usually would see the path and image specs does not exist
Customizing the Cisco Unified IP Phone
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/8941_8945/8_5/english/admin_guide/6921cus.html
I do believe this is planned for a future FW.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks for the answer
Can you add it on the wish list before christmas ?
Philippe
8945 firmware version 9.3(1) supports changing the wallpaper and is on CCO to download.
