Change application behind the directory button on Cisco IP Phone 7970
Hi there,
is there a way to change the behaviour of the directory button on Cisco IP Phone 7970? I need one-click-access to a programm that I've developed. Is there a way to do that?
Any help appreciated. Thx
Peter
Re: Change application behind the directory button on Cisco IP P
that URL is from the Service Parameters on CUCM, it's not on the phone itself. You can get the placed, received and missed calls and then your program.
either change it on the CUCM page or modify the cnf.xml file for that particular phone since all phones have the same info
java
if this helps, please rate
java
www.cisco.com/go/pdi
thanks for your reply...
I got the point that I can add a URL after the three methods provided by the phone. But what I was asking for is a complete replacement of the Cisco call register functionality. E. g. if I press the directory button I want to be forwarded directly to my developed application.
Thanks again for your help.
Cheers
332
