change Background Image remotely
Hi, so thats the question, its possible to change remotely the background image on a IP Phone on a CM 4.2?
Cesar
1 ACCEPTED SOLUTION
Re: change Background Image remotely
Hi you can get a third party software to do this, search for "phone remote" in the voipintegration website. You can download the software as trail or buy. Hope this helps
Thanks for your help!!
Bronze
you can use a simple script in your favourite scripting language to push XML commands to IP Phones via HTTP.
Here is an example of the push command which is using curl:
curl --connect-timeout 1 -s -0 -u ctiuser:cti_password --data-urlencode "XML=http://10.82.1.180:6970/Desktops/320x212x16/omd2-320-212.png http://10.82.1.180:6970/Desktops/320x212x16/TN-omd2-320-212.png" http://10.1.1.1:80/CGI/Execute
Target phone should be associated to the ctiuser account
10.82.1.180:6970 is the HTTP server hosting background images (in this case CUCM 8.0)
10.1.1.1 - target IP Phone address
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
I have tried above curl script. It works fine for 7941, but for the phone model 9971. It doesn't work. Any one try it?
I dont have a favourite scripting language ; but it just went to my "i have to learn about that" list.
thanks for your help
679
