You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Change Caller-ID internally
Hey,
In CM, is there a way to change the caller-id for internal calls so that the called user sees it coming from a different number? I know you can change the Display ID but it still shows the real 4-digit extension in parenthesis.
  • IP Telephony
1 REPLY
Re: Change Caller-ID internally
yes, translation patterns
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
javalenc
if this helps, please rate
HTH java if this helps, please rate www.cisco.com/go/pdihelpdesk
114
