change Calling number in SRST
I have configured SRST and Phones are getting registered succesfully. For SRST phones need to make outgoing calls via E1 and should change the calling number, i tried using translation rule. but in debugs number is not translated. dial-peer and translation rule config is attached.
can anyone help to changed calling number in SRST ?
voice translation-rule 10
rule 1 /.*/ /0472031700/
voice translation-profile SRST
translate calling 10
dial-peer voice 100 pots
description #### Outgoing for SRST ####
translation-profile outgoing SRST
destination-pattern T
direct-inward-dial
port 0/1/0:15
forward-digits all
Regds
  • IP Telephony
Everyone's tags (2)
1 REPLY
Re: change Calling number in SRST
What is your output for the following command on the voice gateway?
test voice translation-rule 10 (type in the calling number here)
this is what I get with your config.
test voice translation-rule 10 4082022001
Matched with rule 1
Original number: 4082022001     Translated number: 0472031700
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
doesn't it show on the external phone like this or are you purley looking at the debug isdn q931?
Voice CCIE #37771
186
