You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Change CUCM 9 Pub to use IP address, instead of hostname?
We're in the process of installing a CUCM version 9 system now and I noticed we had accidentally used the hostname in the System > Server entry for the publisher (which is the only thing we have installed right now, just the base, no config yet) instead of using the IP address, which would disable reliance on DNS.  So...what is the correct process to change that FROM the hostname TO the IP address?
I've seen notes on this page on how to change from ip to ip and hostname to hostname, but not changing from using the hostname to now using an ip.   Understand?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/9_0_1/ipchange/CUCM_BK_C936116C_00_changing-ipaddress-hostname-cucm-90.html
If there's any question about whether it will mess anything up, I'm open to having the tech reinstall CUCM fresh since there's nothing defined on this system yet.  It's totally new (no users, trunks, gateways, etc).
Thanks for your help.
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Simply change it, you may want to restart tftp and phones in order to push the updated config to them.
HTH,
Chris
HTH,
Chris
Thnaks.  It just made me  a little nervous, but I just wanted to be sure.  There aren't any phones defined at all right now.
125
