08-04-2014 11:33 AM - edited 03-16-2019 11:37 PM
I am running CUCM 10.5.1.10000-7 and Unity 10.5.1.10000-7.
I have a single CUCM and Unity.
I change the IP address on the CUCM, updated DNS, and the TFTP setting. Everything on the CUCM works fine with the new IP address except for when I try to call the voicemail pilot number I get a busy signal. I changed the CUCM back to the original IP address then everything works normal again. I have tried stopping/starting services, as well as rebooting when I changed the IP address. I have to be able to change the IP address when I move it to production since I have it on a test VLAN right now.
Solved! Go to Solution.
08-04-2014 11:46 AM
In Unity Connections, Under Telephony Integrations --> Port Group --> Click on Group, then edit --> Servers
Make sure the changes are reflected here to the CUCM servers. If you are using DNS, make sure Unity has updated its DNS settings. I would recommend using IP addresses if you are using host names.
08-04-2014 11:46 AM
08-04-2014 12:25 PM
Thanks a bunch. I forgot about the Edit menu. I have been digging around for hours trying to figure out what is going on. I knew it was on the Unity side since when I changed the CUCM IP address back it worked. I was trying to find a command that listed the configuration, so I could find out where the CUCM was linked in.
08-04-2014 12:27 PM
Glad to help.
08-04-2014 12:30 PM
Hello stive
you have to follow my instruction above , besides the suggestions which already said. You have to update also phone system , to allow import users from your CUCM , as i mentioned above .
please rate all useful information
08-05-2014 10:00 AM
Hello Stiver
I hope my answers helped you also.I am so happy that you solved your problems.
08-04-2014 12:02 PM
Hello
1-After you change the IP address on CUCM , did you change it on CUC?.On CUC " CUC - telephony integration- Phone system" phone system -edit should update to the new IP address .On CUC " CUC - telephony integration- Port group" phone system change the IP address to the new IP address of CUCM .Port group " need reset "no"" .
2-After you change the IP address , you have to check the voice mail ports on CUCM under CUCM "CUCM - advanced features-voice mail ports" , become registered or not .I hope to check all of these information.
08-19-2014 10:21 AM
i have same vm not playign issue in cucm with cuc 10.1
i just reinstall cucm subscriber and apply details in cuc for both pub and sub..
all ports registered...
but when call vm pilot from ip phone..giving beep tone..
how can i fix this issue?
any suggestion will helpfull..
08-19-2014 11:10 AM
Hello
Can you go to CUC-Teleohone integration - Port group and check need reset is no.I have also question , your problem happened after reinstall Subscriber ?.Did you update " Phone system , Port group" with IP address of Subscriber , Can you do also do reset for Port group .
08-19-2014 11:18 AM
08-20-2014 12:21 AM
Hello
1- Did u get your problem after you add the subscriber IP address to CUC ?.
2-Did you list Sub and Pub on your phone system "Edit- AXl " and port group edit "Servers"?.Are u sure that you add correct IPs?.On your CUCM - VM ports , the VM port registered to the IP of subscriber or publisher ?. Can you do reset from CUCM for VM ports , please?.Check also the hunt pilot number and voice mail pilot ?.
3-Finally if you are sure from your configuration ,yup you can do restart for CUC , ssh CUC - type username and password , then type utils system restart .
Please rate all useful information
