Change Default Greeting Length
Is there a way to increase the default greeting time to more than 30 seconds. Unity 4.2.1 thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Change Default Greeting Length
Hi Pete,
Hope all is well my friend!
Class of Service Greetings Settings
The class of service greetings setting specifies the maximum length of greetings.
Subscribers > Class of Service > Greetings Page
Maximum Greeting Length in Seconds Select the recording length allowed to subscribers assigned to this COS for recording greetings.
The range is 1 to 999 seconds.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/administration/guide/ex/sag_0150.html#wp1057646
Hope this helps!
Rob
Hi Pete,
Hope this helps!
Rob
Hello Rob
thank you very much for the quick answer. This is what I needed.
Hey Pete,
You are most welcome my friend!
Take care,
Rob
118
