Community Member
Change Display on 7911
How do I change the display from "Your current options" to something like "John Smith?" The phone is registered in Call Manager 4.2. I have done this on a 2811 with CME through the telephony-services line. Not sure how to do it from the GUI of Call Manager.
1 REPLY
Green
Re: Change Display on 7911
You need to edit the Dictionary
but this will give youthe same option for all phones, you can try to edit Line text label
124
