Change FAC Beep to recorded message?
Hi,..
i have running  a cisco Callmanager version 8.5. My question is, can i change the doble beep to a recording message when you try to make a call with the FAC feature enabled?
my final users are not used to hear that doble tone. they prefer a human voice invite them to input the code
is there another way to configure it? can i insert a voice recording instead the double beep sound?
best regards
MHO
1 ACCEPTED SOLUTION
Miguel,
Unfortunately, there is no option to change the double tone instead of a recording.
Please refer to the following information:
Cisco Unified Communications Manager Features and Services Guide, Release 9.1(1)
Client matter codes and forced authorization codes
http://tools.cisco.com/squish/8B9E8
Miguel,
ok,
thank you for your help!!!
it would be great adding this feature on FAC options.
Best regards
Miguel
Are there any option to
Are there any option to change double beep to triple?
150
