Change Format of Caller ID
Damien Ball
I'm interested in formatting the caller ID information that comes in from our PRI.  I've received requests to make the output more readable for the users.  When a call comes in, we see "1234567890".  I would like it to show the same number, but show it in the following format if possible "(123) 456-7890)".  How can I do this?  I'm using Call Manager 7.1.3.
paolo bevilacqua
Sorry, it is not possible to do that.
5 Replies 5
paolo bevilacqua
Sounds like ciscoscripts.com needs to get on that
Unfortunately it is not possible to do that because calling and called numbers are purely numeric fields, and messing with them is likely to cause further trouble or lack of interoperability.
Aww, that's unfortunate.  It would be nice if they provided a way to make the numbers presentable.  There isn't a way to do this with called party transforms? I know they're mostly used to transform one number into something else without changing routing, but it would be cool if this would work.
No, calling party transformation patterns cannot do this.
Calling Party Transform Mask
Enter a transformation mask value. Valid entries for the NANP include  the digits 0 through 9; the wildcard characters X, asterisk (*), and  octothorpe (#); and the international escape character +.
If the Discard Digits Instructions field is blank, the Prefix Digits  (Outgoing Calls) field is blank, the Calling Party Transformation Mask  field is blank, and the Use Calling Party's External Phone Number Mask  is not checked, no calling party transformation takes place.
If you try to enter () you'll get an error message stating the valid entries are... and the same I just pasted.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
