08-25-2010 06:03 AM - edited 03-16-2019 12:27 AM
I'm interested in formatting the caller ID information that comes in from our PRI. I've received requests to make the output more readable for the users. When a call comes in, we see "1234567890". I would like it to show the same number, but show it in the following format if possible "(123) 456-7890)". How can I do this? I'm using Call Manager 7.1.3.
Solved! Go to Solution.
08-25-2010 07:51 AM
Sorry, it is not possible to do that.
08-25-2010 07:51 AM
08-25-2010 08:14 AM
Sounds like ciscoscripts.com needs to get on that
08-25-2010 08:21 AM
Unfortunately it is not possible to do that because calling and called numbers are purely numeric fields, and messing with them is likely to cause further trouble or lack of interoperability.
08-25-2010 01:09 PM
Aww, that's unfortunate. It would be nice if they provided a way to make the numbers presentable. There isn't a way to do this with called party transforms? I know they're mostly used to transform one number into something else without changing routing, but it would be cool if this would work.
08-25-2010 02:56 PM
No, calling party transformation patterns cannot do this.
If you try to enter () you'll get an error message stating the valid entries are... and the same I just pasted.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
