01-28-2008 07:31 AM - edited 03-15-2019 08:27 AM
Hi all,
can I change the http port 80 in ccm for accessing the ip phone webpage.
greetings,
Michael
01-29-2008 11:22 AM
AFAIK it cannot be done, you can only block it on the CIPC if you're using the port 80 on your PC for web depelopment testing
01-30-2008 11:46 AM
Hi javalenc,
thanks for your answer. I figured out that the webserver on the phone can not be changed in any way because it is part of the firmware.
greetings,
Michael
