change http port 80 for ip phone web access
Hi all,
can I change the http port 80 in ccm for accessing the ip phone webpage.
greetings,
Michael
Re: change http port 80 for ip phone web access
AFAIK it cannot be done, you can only block it on the CIPC if you're using the port 80 on your PC for web depelopment testing
java
if this helps, please rate
www.cisco.com/go/pdi
Hi javalenc,
thanks for your answer. I figured out that the webserver on the phone can not be changed in any way because it is part of the firmware.
greetings,
Michael
352
