Change Https Port in a CUCM 5.1(3)
Hi experts, i have a Cisco Unified Comunications Manager 5.1(3) and need to change the HTTPS port to access the web administration interface, pretty much since the customer had acomplished this same feature on a CallManager 4.X version. I know that it could be acomplished via the ISS on windows, but is there a way on the server CUCM 5.1(3) on Linux?
Thanks in advance
2 ACCEPTED SOLUTIONS
Re: Change Https Port in a CUCM 5.1(3)
AFAIK this can not be changed, you don't have access to the Tomcat which is the one that handles the web pages in 5/6 versions
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
If you have a NAT device/firewall, you could front end all communication for web via that device and translate the port to something else. On the back end, the nat device should send all communications via the regular https port.
javalenc
java
118
