Change IP CUCM 6.1.5 no cluster with temporary license
I have a CUCM6.1.5 (no cluster) with a temporay license, I need to change the address of the server urgently. After this ip change (couple of weeks), the CUCM will be upgraded to 7.1.5, then we will have a permanent license. Is there something special that I need to keep in mind or can I change the ip without any problems with the commands set network gateway and set network ip eth0
Green
Here is a link to changing IP address
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.html
Remember to change any v/gateway config like dial peers, SIP trunks, MGCP etc etc
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Make sure not to skip over any step on the document, otherwise the database may not start after the process and the server might need to be rebuilt.
Thanks for the reply's, the change went smooth without any problem
382
