09-21-2016 09:55 AM - edited 03-17-2019 08:09 AM
Good day!!
One question, I need changed the language for Attempt Sign-In in one Cisco Unity Connection, I have one Cluster version 11.0, I try install cm-locale-es_CO-11.0.1.1000-1.cop.sgn and some audios changed, but when the users need digit the PIN the audio it sounds in English, this is the configuration:
How I can changed the conversation "Attempt Sign-In" to Spanish ??
Thanks ...
Solved! Go to Solution.
09-21-2016 06:51 PM
Hi Christian,
Please check the configuration in the below setting.
User settings > Edit > Message Settings > Language That Callers Hear >
Please choose the language as Spanish.
Also, please confirm if the Conversation Manager and Mixer services were restarted after you uploaded the locale.
09-21-2016 06:51 PM
Hi Christian,
09-22-2016 06:39 AM
Hi Nirmal,
Yes the error was the configuration in the user template.
Thanks.
