Community Member
Change log in CUCM admin
Hi All
Does any one know if it is possible to see a change log in CUCM 7.
More specific, who have made what changes in CCMADMIN.
Thanks in advance.
Everyone's tags (1)
Super Bronze
Re: Change log in CUCM admin
Take a look at the 'Role-Based Security' logs via RTMT's Collect Logs feature.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Sounds like the place, but when I look there, there is no files. The trace settings on the Role-based Security is active, and set to info.
Do I need to set it up some where?
There are already plenty ot posts on the topic
https://supportforums.cisco.com/message/3049000#3049000
https://supportforums.cisco.com/message/3015830#3015830
https://supportforums.cisco.com/message/3117436#3117436
https://supportforums.cisco.com/message/1319286#1319286
https://supportforums.cisco.com/message/3109430#3109430
PLEASE, search NetPro for answer before posting.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
2769
