change number of rings
Is this the right forum to change the number of rings. I want to change the number of rings from the default of 4 before it goes to voicemail to 6. how can I do that? Is that in Unity or CCM? I am running Unity 4.1 and Call manage 4.2
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: change number of rings
Hi Julio,
Here is the way to change this, "System Wide" :)
Go to Cisco CallManager System Parameters from the Cisco CallManager Administration page. Select Service > Service Parameters.
Select the server to be your IP address and the service to be Cisco CallManager from the drop-down list.
Select Forward No Answer Timer (sec) from the list.
In the Value field, insert the timeout that you would like to configure (the time must be inserted in seconds). The default is 12 seconds so you may want 18.
Click Update on the top of the page.
Note: You do not need to restart the Cisco CallManager service to implement the changes.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080111c18.shtml#solution3
***This can also be changed on a per Device basis on the Phone configuration page via No Answer Ring Duration = x number of seconds.
Hope this helps!
Rob
1 REPLY
Hi Julio,
From this good doc;
Hope this helps!
Rob
155
